Jeff Hiller
COMSOL Employee
8 years ago
Sep 13, 2016, 9:11 p.m. EDT
Have you considered using an app? They allow programming through methods written in JAVA. This can be used to automate repetitive tasks in pre- or post-processing.
Jeff Hiller
COMSOL Employee
8 years ago
Jan 11, 2017, 5:29 p.m. EST
I have added an example that shows how to create a repetitive geometry in the Application Builder in this thread:
www.comsol.com/community/forums/general/thread/133541/
https://www.comsol.com/community/forums/general/thread/133541/
Walter Frei
COMSOL Employee
8 years ago
Jan 12, 2017, 3:30 p.m. EST
Hi All,
Here is another example:
https://www.comsol.com/blogs/using-the-application-builder-to-create-a-koch-snowflake/
Best Regards,
Jeff Hiller
COMSOL Employee
7 years ago
Feb 24, 2017, 8:43 a.m. EST
Updated:
7 years ago
Jun 5, 2017, 10:56 a.m. EDT
There is now also a recorded webinar that shows how to generate a geometry algorithmically with the Application Builder:
www.comsol.com/events/webinar/Automating-Preprocessing-and-Postprocessing-with-the-Application-Builder-Webinar-23741
Edit: There is a new blog illustrating the use of the App Builder to build a randomized geometry:
www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/
https://www.comsol.com/events/webinar/Automating-Preprocessing-and-Postprocessing-with-the-Application-Builder-Webinar-23741
Edit: There is a new blog illustrating the use of the App Builder to build a randomized geometry: https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/
7 years ago
Apr 26, 2017, 10:17 a.m. EDT
Hi Jeff and if we have never used JAVA ,, the app builder could be always used or not?
Jeff Hiller
COMSOL Employee
7 years ago
Apr 26, 2017, 10:51 a.m. EDT
I am assuming your question is still with regards to automating geometry creation. Doing so in the Application Builder does require some Java coding.
There are many other things you can do in the Application Builder that do not require any Java coding.
You can also automate creation without using the Application Builder by using MATLAB coding instead (This requires LiveLink for MATLAB).
Nicholas Goldring
Certified Consultant
7 years ago
Apr 26, 2017, 2:30 p.m. EDT
The application builder sounds like a great way to achieve this; another easy solution may be using livelink with excel.
Nick
Nick
