Hello Stefan Eidelloth
2 decades ago
Mar 11, 2010, 4:37 p.m. EST
Hey, i have the same problem
i push the icon restart y works.
2 decades ago
Mar 12, 2010, 2:06 a.m. EST
My first reaction is that you are hitting a numerical limitation (you case is a typical examples of the type I send myself to COMSOL support).
As you say, normally you should have a denser mesh where your gradients are steep
Cannot comment further
2 decades ago
Mar 12, 2010, 2:08 a.m. EST
If it works on second try with a "restart" it could come from the initial conditions, since normally a restart ""re-start" from current level of already calculated results
2 decades ago
Mar 17, 2010, 10:12 a.m. EDT
Hello Mr. Ivar
Can you give me some advice with the following errors.
Error:
Time 1.386578133869988:
Error in Jacobian computation:
Undefined_value_found_Solvermodel
Undefined value found in the stiffness matrix.
Error:
Time 5.125383036305885:
Nonlinear solver did not converge.
I'm looking forward to your reply.
Thank you.
N.L
Hello Mr. Ivar
Error:
Error:
Thank you.
N.L
2 decades ago
Mar 18, 2010, 3:18 a.m. EDT
unfortunately no apart that forme it means you have a complex model ;)
But it looks like there is un undefined variable, so are you sure your BC are real everywhere or over the time ?
For the second it's eitherthe solver is stuck typically on a steep edge of some change, or it does not have enough steps to converge, and you should increase the maximum allowed steps
Try to split your problem, or solve just one physics to check that it is fully possible to fiond a solution in a simpler case
2 decades ago
Mar 18, 2010, 4:20 a.m. EDT
Hello Mr. Ivar KJELBERG
Thank you for your advice.
I sent a private message to Mr. Ivar.
Please help me.
Sincerely,
N.L
nhhieubk@gmail.com
Please help me.
Sincerely,
N.L
nhhieubk@gmail.com
2 decades ago
Apr 13, 2010, 10:29 a.m. EDT
Hi Stefan
Have you got any solution to this problem?
docnurulhasan@gmail.com
Hi Stefan
2 decades ago
Apr 13, 2010, 1:17 p.m. EDT
I did not further work on that specific issue
and i did not try the "restart option",
but please keep us updated if you do.
Currently I am working on a model with a
conductive boundarie instead of a resolved emitter.
This way I can avoid high gradients.
Stefan
Stefan
2 decades ago
Apr 13, 2010, 4:55 p.m. EDT
Hello All..!!!
I was having the same problem And I could fix it changing the Intial Value and the Values of variables not solved Option inside the Solver Manager...this may be happening because You have selected "Zero" for Variables not Solved option...try this way and let me know the results...
Leo
Hello All..!!!
Leo
2 decades ago
Apr 16, 2010, 9:34 a.m. EDT
I had the same problem.
The reason is possibly that initial value is zero in the first calculation step. I changed the initial value from zero to a expression not Zero.
It worked.
It worked.
Jul 23, 2010, 5:04 p.m. EDT
I had this problem as well in my 3D model. Initially I thought this was a mesh problem and that I need only refine it. This though did not correct the problem. Reading the above comments I set the 'Initial value' in the Solver Manager window to 'Initial value expression' instead of 'Initial value expression evaluated using current solution'. I then provided initial values in all application modes (as well as weak form terms that I specifically defined) before running the model and this seemed to work.
Cheers
Aaron
RMC
Canada
Cheers
Aaron
RMC
Canada
Roopesh Mohandas Syamaladevi
Nov 4, 2010, 11:15 a.m. EDT
I am facing a similar problem now. I am trying to couple heat and mass transfer in a transient problem. For mass transfer, there is drastic difference in concentrations between subdomains. In one of the boundaries, sublimation is assigned. Please find the attached file. I set the 'Initial value' in the Solver Manager window to 'Initial value expression' and it did not work. I tried to do using stationary solver and store the values. However that also didn't work.
Thank you so much for your time.
Roopesh
Roopesh
Jan 25, 2012, 6:58 a.m. EST
Hi Stefan,
I am having the same problem, and I am also trying to solve a model for semiconductor. Can we share our experience doing this?
You can write me to gsantil@ieee.org
According to my lectures, there two options that I have to test:
- to modify the initial values.
- To modify the mesh.
I am trying both options, but without obtaining good results until now.
Best regards.
Gerard Franz
Hi Stefan,
Best regards.
Gerard Franz
Jan 25, 2012, 8:39 a.m. EST
Hi Gerard,
it is long time ago I worked on that issue. You might try to have an initial value expression with non-zero slope (if you did not already do so). And you might want to have a look at our CoBoGUI:
www.isfh.de/institut_solarforschung/software.php?_l=1
It uses a model where diffused regions are simplified to special boundary conditions.
Good luck,
Stefan
Hi Gerard,
http://www.isfh.de/institut_solarforschung/software.php?_l=1
Good luck,
Stefan
8 years ago
Mar 22, 2017, 6:54 a.m. EDT
Updated:
8 years ago
May 19, 2017, 12:53 p.m. EDT
