Plot Temperature wrt Extra Dimension in Thin Layer of Heat Transfer module
Posted Jul 13, 2017, 2:02 p.m. EDT Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Geometry Version 5.3 6 Replies
Dear all:
Thank you for clicking into this question.
I have a very simple structure for heat transfer analysis:
A very thin film (10nm) on a substrate (1mm).
The following is the domain/boundary name and the heat transfer gadget I apply
Block 1 (Heat Source)
Block 2
Block 3
--------Boundary 1 (Thin Layer)-----------
I would like to get the "Temperature" across the "thin layer", i.e., the T drop across the thin thickness.
The documentation said I should create a "Study 1/Solution 1 (2)" to accommodate the component "Extra dimension from thin layer"
Then use "1D plot group" with "Line graph" to plot it.
However, when I set the "y-Axis Data" as "comp7.ht5.tl1.Txdim"
and "x-Axis Data" as "nz normal vector"
and plot
the error message comes out and said
Undefined variable.
- Variable: comp7.ht5.tl1.Txdim
- Geometry: ht5_tl1_xdim1_xdim
- Domain: 1
- Expression: comp7.ht5.tl1.Txdim
- Plot: lngr1 (Line graph)
Is there any suggestion on this situation.
Thank you very much for your patience in reading and answering.
Block 2
Block 3
and plot
Undefined variable.
- Domain: 1
6 Replies Last Post Jul 14, 2017, 11:55 a.m. EDT
