Convert space between lines to Solid or surface
Posted Sep 14, 2017, 5:33 a.m. EDT Geometry Version 5.3 7 Replies
I´m new at COMSOL. My first question according to the geometry is the following...
I built a parametriced Body with Lines. Now i want to make the space between the lines to surfaces or make the whole space between the lines to one solid. But with the convert function it doesn´t work. Can anybody help me?
Thankyou!
Hello Alessandro, I am assuming that you are working in 2D, or in a workplane (if in 3D) - otherwise bounding lines are not enough to uniquely define surfaces. If so, the approach you are describing is correct and illustrated by the attached file. This suggests that you'll want to post you .mph file so other users of the Discussion Forum can see exact how you are going about it (Perhaps there is a gap somewhere, etc, it's hard to tell without the ability to play with your file). Best, Jeff
-------------------Jeff Hiller
Hello Jeff,
here you can see my model. Thanks for your help!
I'll refer to my earlier post: in 3D, lines do not uniquely define surfaces. If the surfaces you are trying to create are planar (which seems obvious to me but is not obvious to a computer...), you can create them in a 3D geometry by working in workplanes. It's bit tedious because to follow that recommendation you will need to create 6 workplanes, etc. But if indeed the surfaces you want to create are planar, your geometry can be created in a single step using the "Pyramid" tool, and I would recommend you go that route instead of the workplane route. Best, Jeff
Hey Jeff,
i was also thinking of using the pyramid tool. But I want my model to be variable which means, I want to play with the Volume, the height and the angle of my volumebody. Thats why i chose this a little bit strange method with all the lines. So now in my parameters I can change for example the Volume - click draw all - and then my model changes automatically. I´m not sure if that also works with the pyramid tool...??
Alessandro
Absolutely. See the attached file.
Looks much easier than my model. But one thing - which is important for me - doesn´t work anymore with your model. When I change for example the Volume V_sp or alpha in my parameter list I get an error and the model doesn´t change. This was possible with my model...You have an idea, how this could work?
edit - now it´s working! Thank you very much for your solution!
For completeness sake, and to somewhat walk back what I posted earlier, I should say that there is a way to create surfaces that are not planar based on bounding lines. It consists in using the "Cap Faces" capability. Note that Cap Faces is only available if your license includes one of COMSOL's optional CAD import products (i.e. one of the following products: CAD Import Module, Design Module, or one of the LiveLink for CAD packages).
If the bounding lines happen to be planar, Cap Faces will create the planar surface you expect. If they are not, COMSOL picks one of the possible surfaces.
The use of Cap Faces is illustrated in the attached file, where I moved one of the vertices to skew some of the faces.
For more info on Cap Faces, see also https://www.comsol.com/blogs/meshing-cap-off-for-cap-on/ .
Suggested Content
- BLOG How to Convert Point Cloud Data to Surfaces and Solids
- FORUM heat transfer with surface to surface radiation and solid mechanics
- BLOG Modeling a Pierce Electron Gun in COMSOL Multiphysics®
- KNOWLEDGE BASE Two-Phase Flow Modeling Guidelines
- FORUM State-Space model for surface to surface radiation
