Illegal Vertex Selection Error
I'm working to couple a PDE model to a Heat Transfer model for a biomedical application. I have coupled the two shapes through linear extrusions using vertices. When I attempt to solve the model, the error comes up saying "Illegal vertex selection. Error in multiphysics compilation." Any suggestions? I made sure to select the corresponding vertices in the same order on both shapes, but that doesn't seem to be the problem.
Thanks!
2 Replies Last Post Aug 1, 2011, 4:20 a.m. EDT
Posted: 1 decade ago Aug 1, 2011, 3:51 a.m. EDT
I have a similar problem, however with the standard heat transfer (ht) module.
I have tried all that I can think of! Any suggestions?
Thank you, Michael
I have a similar problem, however with the standard heat transfer (ht) module. "Illegal vertex selection. Error in multiphysics compilation." I have tried all that I can think of! Any suggestions? Thank you, Michael
Posted: 1 decade ago Aug 1, 2011, 4:20 a.m. EDT
I found a workaround for my problem:
I had a Linear Extrusion over 3 connected boundary elements. I selected the respective source vertices in the order the boundary elements appear in the selection (ordered by numbers), but it still did not work.
Once I split the Linear Extrusion into 2 Linear Extrusions, one over 2 boundary elements the other over only one, it worked!
Don't ask me why!
Regards, Michael
I found a workaround for my problem: I had a Linear Extrusion over 3 connected boundary elements. I selected the respective source vertices in the order the boundary elements appear in the selection (ordered by numbers), but it still did not work. Once I split the Linear Extrusion into 2 Linear Extrusions, one over 2 boundary elements the other over only one, it worked! Don't ask me why! Regards, Michael
