Edgar J. Kaiser
Certified Consultant
6 years ago
Jan 20, 2019, 10:36 a.m. EST
A few comments:
- Typically you would not mesh the metal domain and use impedance boundary conditions at the surfaces instead.
- If the coating is thinner than a few skin depths this approach gets inaccurate because current is flowing in different materials. Skin depth can be calculated analytically.
- A frequency scan over orders of magnitude is difficult because the mesh must resolve the wavelength.
- From basic considerations it is straightforward that the current density is the higher the higher the conductivity of the surface layer is. That is why we put silver coatings on RF components.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
A few comments:
Cheers
Edgar
6 years ago
Jan 20, 2019, 1:17 p.m. EST
Dear Edgar,
Thank you for your rapid and factual answer. As for the third point. I can do in manually for example 10 Mhz 50 MHz 1 GHz etc. At the beginning I don't need to have a lot frequency measurements.
As for the last point - I fully agree, but probably forgot to say that my goal is completely opposite. I want to cover the high conductive conductor (copper) by the conductor which has the lower conductivity.
The think is to find the proper configuration which provide the highest losses in this frequency band. I want to use skin effect to precipitate the energy of high frequency which I want to get rid of, into heat.
On the other hand I can chose the circuit excitation and connect the 3D coil into my signal (damping oscillation with very short rising time).
Wheter my coil model in STP file is correct ?
Krzysztof
Dear Edgar,
Krzysztof
Edgar J. Kaiser
6 years ago
Jan 20, 2019, 4:21 p.m. EST
Updated:
6 years ago
Jan 20, 2019, 4:22 p.m. EST
Krzystof,
the coil looks ok. It took a while to import it. You could generate it inside Comsol using a spiral spine curve and sweep the cross section along it.
It may be a challenge to mesh the the thin surface domain. You may try to sweep a mesh from the end surface through the coil. A boundary mesh may be another option.
You need to resolve the thickness of the layer with 3-4 elements or more depending on the accuracy requirements.
For your objective you will indeed need to mesh the thin layer and use an impedance BC on the inner Cu conductor.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Krzystof,
Cheers
Edgar
6 years ago
Jan 21, 2019, 12:29 a.m. EST
Updated:
6 years ago
Jan 21, 2019, 4:25 a.m. EST
Thank you very much again Edgar. This information will be the strat point for me in seting up the model.
Krzysztof
Krzysztof
