Updating a Geometry during solution - physics driven phase change
Posted Jun 12, 2021, 5:18 p.m. EDT Interfacing, Simulation Apps, Geometry Version 5.6 0 Replies
So here's what I'm trying to do:
Imagine a volume where you inject, using a probabilistic model and a coupled physics (temperature field in my case) defects or "bubbles" inside a material matrix.
Once injected the bubbles then grow, driven by a force.
At every new time step of the study, the geometry should be updated, injecting in a semi-stochastic fashion new bubbles.
To define the problem : I am trying to simulate the germination and growth rate of phase change in a phase change material. I currently have 2 issues:
- I need to inject "seed" nano-clusters inside my material matrix that will act as the starting point of my new phase growth
- The only way I found to "realistically" inject nano-clusters is by this tutorial that uses application builder and java. I work in linux cluster --> No app builder or java available in comsol. Can I code somewhere else and send my files to comsol for "interpretation" ? I get inspired from this: https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/
Following the injection of the clusters, the level set method can be solved using either CFD or mathematics interface, but since germination and growth are happening at the same time, I need to initialize my clusters for level set to deform later AND inject new ones during simulation time.
Does anyone have any ideas ? Is there a method /module more suited ?
Thanks in advance, Marios
Hello Marios Barlas
