Robert Koslover
Certified Consultant
3 years ago
Oct 3, 2022, 3:18 p.m. EDT
Updated:
3 years ago
Oct 3, 2022, 3:20 p.m. EDT
Consider applying an "impedance boundary condition" at the finite-conductivity surfaces, and remove the volumes of those domains from the computational space. If necessary, you can also use a short section of PEC that joins to the finite conductivity material. For materials like copper, do not mesh the interior of the material. You won't be computing fields inside it, for this kind of problem. Rather, use the impedance boundary conditiion to represent it as a surface with conductive losses.
3 years ago
Oct 5, 2022, 5:58 a.m. EDT
Updated:
3 years ago
Oct 5, 2022, 5:59 a.m. EDT
Thanks so much for your reply, Robert!
I tried to apply the impedance boundary condition to the signal trace, but I get the "not applicable" message (see attached). The model runs but from the results it's obvious the IBC it's being ignored and the conductor losses are not being modelled.
Could you please elaborate on how to apply this condition?
Jorge.
Jorge.
Edgar J. Kaiser
3 years ago
Oct 5, 2022, 8:15 a.m. EDT
Jorge,
the impedance boundary only works on external boundaries and it seems your lossy boundary is an internal one.
I think you only need to assign a boundary material to the respective boundary and the transition boundary should work.
A domain material assignment isn't working for boundaries.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Jorge,
Cheers
Edgar
3 years ago
Oct 7, 2022, 5:01 a.m. EDT
Thanks Edgard! Apparently it was indeed just a matter of properly selecting the boundaries fir the materials & TBC . The model now runs; I will go into analyzing the results to see if they make sense.
Cheers,
Jorge.
Cheers,
Jorge.
