a question in the "electrochemical_polishing" example in comsol model library.
Dear Ivar Kjelberg,
I am a comsol user, recently i am learning to use the "deformed geometry" function in comsol 4.2a,
There is a good example in the model library named "electrochemical polishing".
I don't undstand, in the "Deformed Geometry"-->"Prescribed Mesh Velocity 2" setting,
the "Prescribed y velocity" was setted as "-K*(-ec.nJ)" , the current density "ec.nJ" is normal to the surface,but the velocity in setting only has "y" component. Why?
"normal current density" should match the "normal deformed velocity", not just y component.
I was confused!!!
in "Prescribed Mesh Velocity 2" setting, the coordinate system can be changed from "global coordinate system" to "Boundary System 1 (sys1)", correspondingly, the "Prescribed y velocity" option will be switched to "Prescribed n velocity", it is the right normal velocity. Why comsol didn't do this in the above example for model library?
Looking forward to your reply!
Your help and information is deeply appreciated!!!
Sincerely,
Luyao
2 Replies Last Post Sep 17, 2012, 5:35 p.m. EDT
Posted: 1 decade ago Sep 16, 2012, 2:49 a.m. EDT
Hello
unfortunately I d onot have all COMSOl modules, so I cannot open that example, the best is to as "support", I can only guess, 1) a possibility is that your boundary is horizonal, hence its normal is along Y and nJ and y component of J are equal. 2) that there is an error and the coordinate used are not correctly selected, as you suggest.
Now boundary coordinates are nice to use in 2D, far trickier in 3D as you have still one normal but two tangential, not necesarily uiquely defined or not as one could expect, for all cases)
Hello unfortunately I d onot have all COMSOl modules, so I cannot open that example, the best is to as "support", I can only guess, 1) a possibility is that your boundary is horizonal, hence its normal is along Y and nJ and y component of J are equal. 2) that there is an error and the coordinate used are not correctly selected, as you suggest. Now boundary coordinates are nice to use in 2D, far trickier in 3D as you have still one normal but two tangential, not necesarily uiquely defined or not as one could expect, for all cases) -- Good luck Ivar
Posted: 1 decade ago Sep 17, 2012, 5:35 p.m. EDT
Dear Ivar,
Thank you very much for your information!
Luyao
Dear Ivar, Thank you very much for your information! Luyao
