Face Cannot Be parameterized
Hi all;
I try to import a STL file to Comsol 4.3a but this error appeared "Face Cannot be parameterized"?
Any help?
Thanks in advance :)
4 Replies Last Post Mar 20, 2013, 12:28 p.m. EDT
Hello Amr Abdelghany
Posted: 1 decade ago Jan 28, 2013, 10:45 p.m. EST
I had the same problem. Anyone can help?
Hello, I had the same problem. Anyone can help?
Posted: 1 decade ago Jan 29, 2013, 1:47 a.m. EST
from my experience, not much to do as STL is not a "solid" 3D format, if you could use STEP, ACIS or Parasolid or one of the native 3D geometry formats you will have more chances to get the import successful
Hi from my experience, not much to do as STL is not a "solid" 3D format, if you could use STEP, ACIS or Parasolid or one of the native 3D geometry formats you will have more chances to get the import successful -- Good luck Ivar
Posted: 1 decade ago Mar 20, 2013, 12:19 p.m. EDT
Hi!
I managed to find a solution. It is not trivial nor free. We can import the .stl file with +CAD (Simpleware), convert it to a mask and then save/export it as a +ScanIP (simpleware) file. Once in +ScanIP we open the file with the mask and we create a NURBS surface from the mask. We can export the mesh in different formats that comsol accepts. I tried with .igs extension and it worked.
I followed a suggestion here
www.comsol.com/press/news/article/117/
www.comsol.com/products/interfaces/simpleware/
Hope it helps someone.
Hi! I managed to find a solution. It is not trivial nor free. We can import the .stl file with +CAD (Simpleware), convert it to a mask and then save/export it as a +ScanIP (simpleware) file. Once in +ScanIP we open the file with the mask and we create a NURBS surface from the mask. We can export the mesh in different formats that comsol accepts. I tried with .igs extension and it worked. I followed a suggestion here http://www.comsol.com/press/news/article/117/ http://www.comsol.com/products/interfaces/simpleware/ Hope it helps someone.
Posted: 1 decade ago Mar 20, 2013, 12:28 p.m. EDT
I am also face the same problem and that's why i am join this forum today to participate in discussion and find the solution of this problem. Thanks for explain this issue, now i will try to do through this way.
