number of nodes in a COMSOL mesh?
Hello, I would like to know how to access the number of nodes in a COMSOL mesh? Thanks for your help
4 Replies Last Post Feb 21, 2025, 5:18 a.m. EST
Posted: 8 months ago Aug 30, 2024, 2:03 p.m. EDT
Well, you can find quite a lot of info about any mesh from within the Model Builder. For example, by going to Component 1, then right-click on Mesh 1, and choose Statistics. This will bring up info about the number of vertices and the various numbers of various types of elements in your mesh, along with various options for displaying/listing their characteristics. I hope that helps.
Posted: 8 months ago Sep 4, 2024, 6:09 a.m. EDT
I you have access to LiveLink for Matlab you can use the function mphmeshstats to retrieve the coordinates and connectivity for all the mesh types you have in the mesh.
Lars Gregersen
Comsol Denmark
I you have access to LiveLink for Matlab you can use the function **mphmeshstats** to retrieve the coordinates and connectivity for all the mesh types you have in the mesh.
Posted: 2 months ago Feb 17, 2025, 10:25 p.m. EST
Gregersen
Dr Gregersen, how about the syntax when there are multiple meshes?
>Gregersen Dr Gregersen, how about the syntax when there are multiple meshes?
Posted: 2 months ago Feb 21, 2025, 5:18 a.m. EST
help mphmeshstats gives you the answer.
E.g. stats = mphmeshstats(model, 'mesh2')
If you write stats = mphmeshstats(model, and press TAB then Matlab will show you the valid mesh tags
Lars Gregersen
Comsol Denmark
help mphmeshstats gives you the answer. E.g. stats = mphmeshstats(model, 'mesh2') If you write stats = mphmeshstats(model, and press TAB then Matlab will show you the valid mesh tags
Reply
