Surface generation
Probably a rookie question, but what is the command to generate a surface from a list of segments and arcs? In 2D axi-symmetric, is it possible to include the axis of rotation to obtain a closed surface? Thank you
4 Replies Last Post Sep 24, 2024, 1:52 a.m. EDT
Posted: 2 months ago Sep 19, 2024, 3:24 a.m. EDT
It would not be a 2D-axisymmetric problem, if you revolve it into a surface in 3D space. But you can make a 3D component, draw your 2D geometry on a work plane, and then revolve that.
If it is only for post-processing, you can extrude/revolve a 2D-axi solution into a surface plot.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
It would not be a 2D-axisymmetric problem, if you revolve it into a surface in 3D space. But you can make a 3D component, draw your 2D geometry on a work plane, and then revolve that. If it is only for post-processing, you can extrude/revolve a 2D-axi solution into a surface plot.
Posted: 2 months ago Sep 19, 2024, 12:57 p.m. EDT
Thank you for the reply, but the first question really was if in 2D I can build a surface starting from a the list of its sides.
Posted: 2 months ago Sep 23, 2024, 9:59 a.m. EDT
Have you considered applying a conversion operation? I'm not sure if this is the same thing as what you are talking about, but if you have a set of connected line segments, arcs, etc., in 2D, then in the Model Builder, right-click on Geometry, then click on Conversions, then Convert to Solid. Select your objects (the segments and arcs) and build.
Have you considered applying a conversion operation? I'm not sure if this is the same thing as what you are talking about, but if you have a set of connected line segments, arcs, etc., in 2D, then in the Model Builder, right-click on *Geometry*, then click on *Conversions*, then *Convert to Solid*. Select your objects (the segments and arcs) and build.
Posted: 2 months ago Sep 24, 2024, 1:52 a.m. EDT
Ok, I was not clear on the solid part. It took a few attempts but I think it worked. Thank you.
Reply
