d operators are not defined properly in the current context, please use dtang or average operators and d operators instead. - Expression: D (comp1.c,x)
Hello,everyone! Could anyone help me with this problem? Comsol is used to calculate the coupling problem of solid mechanical field and material transfer field. When no fractures were added in the material transfer field, it could be solved normally. However, when fracture were added in the mass transfer field, the following errors would occur. "d operators are not defined properly in the current context, please use dtang or average operators and d operators instead. - Expression: D (comp1.c,x) ' - I will appreciate if anyone could help me with this problem! Thanks a lot!
0 Replies Last Post Nov 12, 2024, 4:01 a.m. EST
Hello Yaping Deng
Reply
