Postprocessing-visualization of symmetric profiles
I solved the thermal stresses in a plate using two faces of symmetry, saving computational cost. I wonder if COMSOL allows me to mirror the two symmetric faces and visualize the deformation in the full plate rather than in the quarter that I simulated.
1 Reply Last Post Apr 11, 2013, 2:52 p.m. EDT
Posted: 1 decade ago Apr 11, 2013, 2:52 p.m. EDT
indeed at least in the most recent versions (as the one you quote, yuo can revolve a 2D-axi or extrude a 2D or mirror a 2D or 3D model, you do that under the Data Set node (right click+...) then you can add a specific higher dimension plot node and refer to your new data set
Hi indeed at least in the most recent versions (as the one you quote, yuo can revolve a 2D-axi or extrude a 2D or mirror a 2D or 3D model, you do that under the Data Set node (right click+...) then you can add a specific higher dimension plot node and refer to your new data set -- Good luck Ivar
