Generalized alpha or BDF?
What is the difference between "Generalized alpha" and "BDF" time dependent solvers?
Is there any specification that each one is better for a certain type of simulation?
i.e. For a thermal-electrical-mechanical coupled transient analysis which one is better?
Best regards
4 Replies Last Post Oct 3, 2013, 1:49 p.m. EDT
Posted: 1 decade ago Oct 3, 2013, 6:09 a.m. EDT
I'm not a big expert with numerical solvers, but roughly speaking:
1) BDF is a multistep method, this means it keeps and uses informations from previous steps to calculate the next one.
It's very good choice for stiff equations but has some problems with damping.
2) Generalized Alpha (no idea of the algorithm behind it, sorry) is usually less stable than BDF as it uses less damping but it's more accurate.
Usually you expect Generalized Alpha to perform better in structural mechanics (it was developed for that) and I would say in acoustics (you don't want to have big dampings there). No idea for other kind of physics.
Do you expect sharp transient in your solutions? In that case try generalized alpha. If you have convergence issues use BDF.
EDIT: just found this, it can help you
www.comsol.com/support/knowledgebase/1062/
I'm not a big expert with numerical solvers, but roughly speaking: 1) BDF is a multistep method, this means it keeps and uses informations from previous steps to calculate the next one. It's very good choice for stiff equations but has some problems with damping. 2) Generalized Alpha (no idea of the algorithm behind it, sorry) is usually less stable than BDF as it uses less damping but it's more accurate. Usually you expect Generalized Alpha to perform better in structural mechanics (it was developed for that) and I would say in acoustics (you don't want to have big dampings there). No idea for other kind of physics. Do you expect sharp transient in your solutions? In that case try generalized alpha. If you have convergence issues use BDF. EDIT: just found this, it can help you http://www.comsol.com/support/knowledgebase/1062/
Posted: 1 decade ago Oct 3, 2013, 9:17 a.m. EDT
Hello Stefano,
Thank you for the information.
In my simulations, which are thermal-electrical-mechanical coupled, it would be some sharp transient for electrical current. On the other hand, when I consıder contact between parts, then convergence would be a problem.
So, maybe in case of contact it would be better to go with BDF?
Hello Stefano, Thank you for the information. In my simulations, which are thermal-electrical-mechanical coupled, it would be some sharp transient for electrical current. On the other hand, when I consıder contact between parts, then convergence would be a problem. So, maybe in case of contact it would be better to go with BDF?
Eric Favre COMSOL Employee
Posted: 1 decade ago Oct 3, 2013, 12:40 p.m. EDT
Hello!
www.comsol.com/blogs/analyzing-electrical-thermal-conductance-contact-switch/
The corresponding model is included with 4.3b where this kind of multiphysics contact has been implemented and is ready to use.
Regarding BDF vs alpha-gen, in principle you should be able to use one or the other and get comparable results. The solution in case of any visible difference is frequently to adjust the tolerances. As usual, in a multiphysics complicated problem, always try to solve for simple problems before attacking difficult ones!
good luck,
Eric
Hello! http://www.comsol.com/blogs/analyzing-electrical-thermal-conductance-contact-switch/ The corresponding model is included with 4.3b where this kind of multiphysics contact has been implemented and is ready to use. Regarding BDF vs alpha-gen, in principle you should be able to use one or the other and get comparable results. The solution in case of any visible difference is frequently to adjust the tolerances. As usual, in a multiphysics complicated problem, always try to solve for simple problems before attacking difficult ones! good luck, Eric
Posted: 1 decade ago Oct 3, 2013, 1:49 p.m. EDT
Ok.
Thank you for your information.
Best regards
Ok. Thank you for your information. Best regards
