Error after updating: failed to evaluate variable Jacobian
Hi there,
I have this model file that I used to use with earlier version of Comsol, I think it was 4.3.
Now that we updated to 4.3b I get the error "failed to evaluate variable Jacobian" from the emw module.
Variable: mode1.Ezx
Feature: Eigenvalue Solver (sol1/e1)
Structural mechanics works fine. I followed some of the recommendations made to similar posts but it still gives the same error.
Can you please have a look...
1 Reply Last Post Oct 10, 2013, 12:35 p.m. EDT
Posted: 1 decade ago Oct 10, 2013, 12:35 p.m. EDT
I found a fix. I have no idea why it works though! I'm leaving the comment in case someone faces the same issue...
Change the following: Electromagnetic Waves node -> Wave Equation -> Material type: set to Non-Solid.
I'm not sure what this setting does, but my model works now!
I found a fix. I have no idea why it works though! I'm leaving the comment in case someone faces the same issue... Change the following: Electromagnetic Waves node -> Wave Equation -> Material type: set to Non-Solid. I'm not sure what this setting does, but my model works now!
