Applying external strain
Alberto Garcia-Cristobal
Hi All
I am doing simulation to study elastic properties of cylindrical abject. I want to apply external strain on top surface of the cylinder. So how can COMSOL handles such cases?
5 Replies Last Post Nov 13, 2013, 10:58 a.m. EST
Posted: 1 decade ago Nov 12, 2013, 7:10 a.m. EST
Alberto,
it is easy: you apply a strain boundary condition to the surface.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Alberto, it is easy: you apply a strain boundary condition to the surface. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago Nov 12, 2013, 6:24 p.m. EST
Dear Edgar
Thank you for the suggestion but I couldn't get any place yo do it in comsol, i.e to select the 2D surface at the top of the cylinder and apply the required strain value.
Dear Edgar Thank you for the suggestion but I couldn't get any place yo do it in comsol, i.e to select the 2D surface at the top of the cylinder and apply the required strain value. Thanks
Posted: 1 decade ago Nov 13, 2013, 7:50 a.m. EST
There is nothing such as a "Strain boundary condition". It is not a mathematically well defined operation.
If you want to prescribe the strain components tangential to the boundary (which are the only ones that could be prescribed), this can be done using a Prescribed Displacement, where the expressions for the displacements are such that you can retrieve the strains from their derivatives.
Prescribing the individual strain components (even within the plane) is not a well defined operation, since that could violate the compatibility requirement.
Henrik
Hi, There is nothing such as a "Strain boundary condition". It is not a mathematically well defined operation. If you want to prescribe the strain components tangential to the boundary (which are the only ones that could be prescribed), this can be done using a Prescribed Displacement, where the expressions for the displacements are such that you can retrieve the strains from their derivatives. Prescribing the individual strain components (even within the plane) is not a well defined operation, since that could violate the compatibility requirement. Regards, Henrik
Posted: 1 decade ago Nov 13, 2013, 9:39 a.m. EST
Henrik is right of course: it is prescribed displacement you can apply. I was a little sloppy in my response.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Henrik is right of course: it is prescribed displacement you can apply. I was a little sloppy in my response. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago Nov 13, 2013, 10:58 a.m. EST
Thanks all, I got it.
