Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
Nov 16, 2013, 6:18 p.m. EST
If you just need the information for output and not to be used in the simulation itself, you can just use the cut plane feature of the results section of the model tree.
If you need the information within the model tree, you can create work planes within the model where you want to integrate the values. You can create variables and/or coupling variables to compute these quantities.
There are several ways you could do this.
Nov 17, 2013, 11:13 p.m. EST
James,
Thanks for the response.
If I create work planes within the model, wouldn't the values be calculated only on these specific planes?
Can I get cross-sectionally averaged values as a continuous function of x?
James,
Jim Freels
Nov 18, 2013, 11:22 a.m. EST
That is the only way I know how to do it. This type of feature is something that needs to be incorporated into the model in a more user-friendly manner. You also might want to become familiar with coupling variables and then see if using this might also deliver the desired features.
Jeff Hiller
COMSOL Employee
Nov 18, 2013, 11:51 a.m. EST
Hello Kumar,
You can accomplish what you want using a general projection model coupling, see Reference Manual, version 4.3b, page 288. A basic example is attached: the Line Graph 1 node computes the integral of T as a function of x.
Hello Kumar,
May 15, 2014, 11:40 a.m. EDT
Hi Jeff,
I am trying to use general projection in the same geometry as the example model you provided,(a simple rectangular pipe, laminar flow of water with free tetrahedral mesh) in order to plot the average velocity,(spf.U), (average in a yz cross-section) across the length of the pipe (x).
Thank you in advance for your help
Hi Jeff,
