                                2 decades ago
                                Mar 22, 2010, 10:43 a.m. EDT
                                                    Yes you need to calculate a pressure pulse.
and this has nothing to do with comsol but  everything about the physic of the coupling between the laser and the target [ HUGE subject indeed  :-)  ]and also of the accuracy you need for your modeling work [ simple formula existthat will provide with a solution but not very accurate... .
This is something you need to find for yourself or wih expert of the kind of effect you want/need to model
jf
jf
                                2 decades ago
                                Mar 22, 2010, 12:04 p.m. EDT
                                                    Thanks for the quick answer.I am trying to get a solution.It do not have to be accurate.Which simple formula do you mean?
Thanks again,
C.Mannal
Thanks again,
C.Mannal
                                2 decades ago
                                Mar 22, 2010, 1:10 p.m. EDT
                                                    well I dont know how to put it....
but it depends of your problem [ nature of your target, nature of the laser..
 but usually you cannot do numerical simulation of a physic you dont know  or dont master
Comsol like any other fem package is not a magic wand.
this is just a tool and you need to know what to do with it.
this forum is not , I thik about laser matter interaction not am I an expert on this .
but assuming your target is solid and your pulse brief compared to the time "deposition thickness/soundwave of the target" you can use the Gruneisen "gamma"  coefficient that give P=Gamma rho E. rho solid density of the target e deposited total energy to get an estimate of the peak pressure generated you then need to devise a time  profile using impulse conservation and other physical feature of your targets.... again a complicated subject...
and again this is a crude formula valid in narrow range of conditions but often usefull to " debunk a problm or check more sophisticated models..
jf
jf
