Jan 9, 2014, 10:09 a.m. EST
Uhyadav:
Uploading the model would be best, but I know when setting up periodic boundary conditions (BCs) this error can occur if COMSOL cannot determine the orientation of the periodicity. For example, setting all four boundaries of a unit cell as periodic under a single BC node--this is wrong, as each boundary pair (the -x/+x faces and -y/+y faces) needs a separate BC implemented.
However, a "gas sensor" model wouldn't seem to need periodic BCs, unless this is a common practice for MEMS. This error also might occur if you are trying to copy a boundary mesh, perhaps? Again, stating more about your error in context with your model will help others better understand your problem.
-Bryan
Uhyadav:
-Bryan
Jan 19, 2014, 6:21 a.m. EST
we have confusion in setting the periodic condition and ground in case of saw delay line sensor. please he us.
uhyadav
uhyadav
Jan 20, 2014, 8:23 a.m. EST
we are getting out from BC error, a new error occurs as out of memory in eigenvalue solver.
uhyadav
uhyadav
Jan 21, 2014, 10:49 a.m. EST
If this is a 3-D model, you may very well be running out of memory. PBCs on a 3-D model require a great deal of memory (mine usually need more than 32GB of physical memory) and special considerations to the meshing. What are your machine specs?
