Charge Flow in a plasma and Solving Poisson's Eq. COMSOL v3.5a
In general what kind of concerns are there when modeling electron and ion motion using FEM, specifically in a low temperature plasma? If anyone can provide a good reference to a paper or text that discusses in detail issues with meshing, time stepping, etc. I would really appreciate it. I want to solve basic drift-diffusion equations along with energy balance and poisson's equation. My big concern is really solving poisson's equation simultaneously with the drift-diffusion equations since both are strongly dependent on one another. Any advice?
6 Replies Last Post Aug 25, 2011, 2:45 a.m. EDT
Daniel Smith COMSOL Employee
Posted: 1 decade ago Aug 30, 2010, 5:11 p.m. EDT
Dear David, the Plasma Module is designed to model low temperature plasmas. Poisson's equation is solved simultaneously with the drift diffusion and ion transport equations. You can find more information and tutorials here:
www.comsol.com/products/plasma/?tab=tutorials
/ Dan
Dear David, the Plasma Module is designed to model low temperature plasmas. Poisson's equation is solved simultaneously with the drift diffusion and ion transport equations. You can find more information and tutorials here: http://www.comsol.com/products/plasma/?tab=tutorials / Dan
Posted: 1 decade ago Aug 30, 2010, 6:00 p.m. EDT
Hello Dan,
I watched the tutorial on the plasma module. I didn't see how the poisson's equation is implemented. Typically for a an argon GEC model, can comsol 3.5A generally handle solving both the poisson's equation and drift-diffusion equation even with the coupling? What typical concerns should I have with implementing such a model?
-David
Hello Dan, I watched the tutorial on the plasma module. I didn't see how the poisson's equation is implemented. Typically for a an argon GEC model, can comsol 3.5A generally handle solving both the poisson's equation and drift-diffusion equation even with the coupling? What typical concerns should I have with implementing such a model? -David
Posted: 1 decade ago Aug 31, 2010, 12:01 p.m. EDT
Hi, in the Plasma Module Poisson's equation is implemented in the same way as in the AC/DC module except that the space charge density is automatically computed for you based on the plasma chemistry defined in the model. The strong coupling between the electrostatic field and the electron transport is easily dealt with by COMSOL since we always use fully implicit time stepping and we solve for both in a fully coupled manner (as opposed to segregated).
The book keeping and choosing how best to implement these equations in v3.5a is probably going to be very difficult. I would suggest using the plasma module since all these details are automatically taken care of by the software.
/ Dan
Hi, in the Plasma Module Poisson's equation is implemented in the same way as in the AC/DC module except that the space charge density is automatically computed for you based on the plasma chemistry defined in the model. The strong coupling between the electrostatic field and the electron transport is easily dealt with by COMSOL since we always use fully implicit time stepping and we solve for both in a fully coupled manner (as opposed to segregated). The book keeping and choosing how best to implement these equations in v3.5a is probably going to be very difficult. I would suggest using the plasma module since all these details are automatically taken care of by the software. / Dan
Posted: 1 decade ago Aug 31, 2010, 7:58 p.m. EDT
Thank you very much for your input. Before I switch to v4.0 I will see what I can do with v3.5a.
Posted: 1 decade ago Aug 31, 2010, 11:52 p.m. EDT
/ Dan
Such a very amazing link!
moviesonlineworld.com
[QUOTE] Dear David, the Plasma Module is designed to model low temperature plasmas. Poisson's equation is solved simultaneously with the drift diffusion and ion transport equations. You can find more information and tutorials here: http://www.comsol.com/products/plasma/?tab=tutorials / Dan [/QUOTE] Such a very amazing link! -- http://moviesonlineworld.com
Posted: 1 decade ago Aug 25, 2011, 2:45 a.m. EDT
sir:
Hello! I am just simulating the rf plasma discharge with the comsol software. There are some questions .for example :When i simulated there was a note :Failed to find consistent initial values.
Last time step is not converged.I wish you can give me some advice .The modle i have build is in the accessory.
Best wishes to you .
sir: Hello! I am just simulating the rf plasma discharge with the comsol software. There are some questions .for example :When i simulated there was a note :Failed to find consistent initial values. Last time step is not converged.I wish you can give me some advice .The modle i have build is in the accessory. Best wishes to you .
